firing order?
Discussion in 'General Maverick/Comet' started by vvr210, Dec 25, 2013.
  1. vvr210
    vvr210 Member
    Vista,CA
    I am using a distributor cap adapter that has male terminals on a factory distributor. The cap adapter is for an 85 mustang I believe.Do I stick with the original 15426378 or the 302 5.0 firing order?
  2. yellow75
    Tillamook Oregon
    Just use the firing order for the 302 engine in you car,that is if the car is stock and the cam has not been swapped out for a different cam for a 5.0 or 351.
    The reason that it is changed for the 5.0 is because the cam is different and has a different firing order.
  3. iraceitall
    iraceitall Member
    Was a Comet
    Yep, just keep the original firing order.:christmas:
  4. Krazy Comet
    The camshaft determines firing order & nothing else...
  5. vvr210
    vvr210 Member
    Vista,CA
    Thanks everyone.I installed shorty headers yesterday and I took out all the plugs and I couldn't remember what firing order to use when I was done.
    Tomorrow I will go to the exhaust shop to connect my mufflers
    Merry Christmas!
