first drive transmission issues. HELP PLEASE
Discussion in 'Transmissions' started by ptpdub, Jun 9, 2010.
  1. ptpdub
    ptpdub Member
    canada Sk.
    my knowledge of transmissions is very limited, so this might be a simple question but i still need the answer. i put my car together and took it for its first run! motor runs great and the exhaust sounds good. i put the car in gear and stepped on the gas. the transmission goes into gear but it slips. it feels like it goes only half way into gear. i ran the car around the house and put it into the garage.
    here is what i know
    c4 rebuilt with a shift kit (transmission shop said it was a "blue" kit)
    b&m mega shift shifter
    has a BAD leak from the cooling line fittings (not tight enough), (i hope this has something to do with it slipping)
    lots of type f in it
    what is your guess?
    what makes the transmission slip:(
  2. 71gold
    we had talked about the converter not being seated correctly...:huh:
    could it be the pump is gone?
    i am still trying to get mine seated ...:yup:
    Frank
  3. ptpdub
    ptpdub Member
    canada Sk.
    well, i don't think so because i never actually bolted it in all the way with the converter problems, just finger tight.
    second, i don't think a pump would cause it to slip like that ........ i don't think so any way. my understanding is that the transmission will burn up with out a pump but it only drove for aprox. 600 feet. so i don't imagine that is the issue.
    am i wrong?
  4. ptpdub
    ptpdub Member
    canada Sk.
    Please help!!
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    can't you get slipping when you have too much fluid in the tranny? do you know if you topped it off correctly?
  6. ptpdub
    ptpdub Member
    canada Sk.
    well, you sure were right. i pulled 6 liters out of it (it reads as correct now) and it started to smarten right up. it now shifts well but i wonder if it still slipps a littole off the start. could this be my torque converter? it is a 2400 stall and i dont actually know how that should feel. it vilontly spins the tire (one wheel drive) but i still think 1st is week. how should a 2400 feel?
  7. ptpdub
    ptpdub Member
    canada Sk.
    could it be the linkage? i think it is in need of adjustment
  8. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    That's how I felt when I started driving around my car I have the same setup as you too I always thought it was slipping buts its the stall converter that makes it feel like that, add some gears and you'll feel first gear ain't soo week lol I got 4.11's in mine and and it gets up quick haha
  9. ptpdub
    ptpdub Member
    canada Sk.
    what diff did you use?
  10. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
  11. 55crownvic
    55crownvic Member
    colorado springs
    What did you use to get the extra fluid out of the trans?
  12. mojo
    I open the front line on the C4, start the engine and let the pump -pump fluid in a plastic container/bottle. I have rubber lines going to external trans cooler.
  13. ptpdub
    ptpdub Member
    canada Sk.
    that is exactly what i did as well.:thumbs2:
  14. ptpdub
    ptpdub Member
    canada Sk.
    and now the transmission is pooched. need of a 2nd rebuild. only had about 6 hrs drive time on it.:mad:
