First Mav With Question(vin decode)
Discussion in 'Technical' started by MavKatrina, Jul 18, 2004.
  1. MavKatrina
    MavKatrina Member
    Northern VA
    Finally got my mav, any one who can tell me why my mav's body tag says it was made by ford motor of canada IN canada?
    BODY 62A COLOR 3F TRIM BA AXLE 3 TRANS W DSO 17
    VIN 2X91T1XXXXX
    Car appears to be originally grabber blue/6 cyl/3 speeds man.
    -were all mavs built in canada, or is this one different? :confused:
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
  3. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Hey MavKatrina Congrats on finding your Maverick please post pics as soon as you can for us to see. Thanks
  4. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    Ford brought a lot of cars into the US from their Canadian plant. I had a '79 LTD from Canada back when. There was no diference in the cars regardless of which plant they came from. My Stallion was built in Kansas City and you'll find no difference in any nut, bolt, etc. between our cars due to where it was built.
  5. paulsonjosh
    paulsonjosh Member
    MINNESOTA
    MAVERICK
    i can tweel you this much its a 72 mav
  6. dmhines
    Cumming, GA
    Actually the window regulators were different. I know door glass from a Canadian 2-door will not work in a US 2-door ...
  7. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    glad you ended up with a 72!
  8. scott
    scott Member
    new jersey
    katie- if you are lucky, and look under the front seat on the driver side between the padding and the springs, you'll find a VERY BRITTLE build sheet! it was taped onto the car as it went down the assembly line. if it is there, have dad help you remove the front seat so you can get the build sheet out without ripping it. it was a paper telling the guys on the line what to put in your car... a radio? which radio? which tires? really neat thing to have. i took out mine and laminated it! mine still has the masking tape they used to hold it on the car.
  9. Huehunguy
    Huehunguy New Member
    The axle code 3 means you have a 2.79 rear end. 6 would mean 3.00
  10. SuperByelich
    SuperByelich Jesus Is Lord.
    Chincoteague, Virginia
    1971 Maverick Grabber
    The 'X' on your vin number after the '2', is the assembly plant code.. and 'X' means St. Thomas, Ontario. So it was put together in Canada. Mine is from there too.
    Jason
  11. Maverick73
    Lakeland, FL
    Katie pics?
  12. MavKatrina
    MavKatrina Member
    Northern VA
    the pics are coming guys n gals...we have to get a camera and take some first....theyll be on here as soon as we get some.
    -katie
  13. Maverick73
    Lakeland, FL
    O Katie Where and How did you find your car?
