Fixing dented gas tank
Discussion in 'Technical' started by b_ryce70Mav, May 27, 2010.
  1. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I've got a '70 gas tank that I just removed from my Mav with a basketball sized depression in the top. Looks like somebody sat something too heavy on it. Its not a bad dent, no creases or anything, just pushed in. I'm trying to figure out a way to get it out. My thoughts so far are to either remove the sender and try and push/tap it out with a dowel, or see if maybe a body shop can slide one of their airbag things in there and push it out. Any thoughts/ideas?
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    J-B WELD something to it then pull up on it // and you wont even have to pull the tank out // it's worth a shot :tiphat:
  3. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I like it. So redneck it just might work. What was really redneck was how I removed it. Somebody put it in with a gasket or sealant of some sort in addition to all the screws. It wouldn't budge so I put one of my wheels (with tire) on a jack and jacked it up underneath the tank. The adhesive was tight enough to support the rear of the car and lift it off the jack stands, so with a little pressure on it I started shooting starter fluid around the edges and it popped right out.
  4. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Hahaha! I love it! I have a baseball sized dent in the bottom of my gas tank and I think I'm gonna try the JB WELD trick!
  5. 71gold
    pour the gas out...drop a match into the tank...POOF!!!...the dent pops out...:Handshake
    ...J/K...
  6. Craig Selvey
    Fill tank with water and place in freezer. Works on pop cans. (I used to collect them).
  7. Joe Dirt
    compressed air ,filling the tank with air building pressure should push the dent out as long as it has no sharp creases
  8. Moneymaker 1
    Panama City Florida
    Or an M-80!:rofl2:
  9. 71gold
    is that a Monk thing? most people flatten them...:huh:
  10. maverick75
    If he collects them (or use to) why would he want a flat can? :hmmm:
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    This would be my way to do it.:thumbs2:
  12. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I thought about that as well. You would just have to be able to seal up the tank with something that wouldn't give out before the dent popped. The freezer idea is cool, but who owns a freezer that big? Gonna go try the bolt thing right now.
  13. rthomas771
    Using compressed air could also blow out the seams. Try a hair dryer and AirDuster [ame="http://www.metacafe.com/watch/501379/remove_car_dent_with_airduster/"]Remove Car Dent With Airduster - Video[/ame]
