I need some suggestions on how i should go about fixing the rust in the inside corners of the wheel wells were the corner of the quarter panel comes together.
That's not too bad, just as said before. Grind it down to bare metal, then slowly cut and patch. I would treat each panel seperatly. Example, do the outer qtr first, then the inner qtr, then the rocker. -Matt
