Floor Metal
Discussion in 'Cosmetic' started by MaverickMagic, Jun 30, 2013.
  1. MaverickMagic
    MaverickMagic Member
    Charlotte, NC
    1973 Maverick
    I am trying to fix the rust holes in the floor of my 73 maverick. Does anyone know what gauge of steel is used for the floor?
  2. rthomas771
    I think it's 18
  3. olerodder
    olerodder Member
    NorCal
    I just measured my floor (where the hole is for my shifter) and it came out 0.0635" or 16 gauge..........................but this equates to galvanized 16 gauge steel (0.0598" for std steel), 18 gauge is 0.0478" for standard steel and 0.0516" for galvanized.
    But my floors are painted and that could account for the 0.0037" difference between standard steel and galvanized.........in my case anyway.
  4. MaverickMagic
    Charlotte, NC
    1973 Maverick
    Ok thanks a lot guys. And also does anyone know if the sheet metal will EVER be reproduced??? I know there has been a lot of discussion about this but does anyone have any facts?
  5. Dave B
    If you are welding in flat sheet metal, stay away from Galvanized, it'll make you sick.
  6. Craig Selvey
    If I had to bet money (which is what we are asking a manufacturer to do by reproducing floorboards) I would say they will NEVER be made.
  7. olerodder
    olerodder Member
    NorCal
    Craig is right.......................Since I have been looking for another Maverick/Comet to make into a daily driver I have talked with a few friends that do tooling for some of the bigger Mustang vendors...........and their question was how many thousands of Mavericks were made and would someone be willing to spend;
    $500,000 for a floor tool
    $250,000 for each front fender tool
    $400,000 for each quarter tool
    or maybe someone could buy them from Ford..........if they were still around and even then they would probably have to be redone.
    I doubt there would be anyway for someone to make any profit on selling sheetmetal parts for the Maverick unless the prices were $$$$.....IMHO
  8. 71gold
    did you fix the reason the floor has rust holes...:huh:
  9. mav1970
    Frank hit the nail on the head
    I repaired all of my floor issues but then went to the root cause of my floor rot and repaired the cowl vents - could also be the windshield seal :thumbs2:
  10. MaverickMagic
    Charlotte, NC
    1973 Maverick
    Luckily there are only 2 holes and they are both at the front of the footwells. We know there are no leaks in the car and it is a minnesota car so that explains a lot of the rust issues. Minnesota Car = Minnesota Rust
  11. Randy S
    Randy S New Member
    1972 Maverick Grabber, 1972 Maverick Sedan, 2005 Toyota Tundra
    Repro floor pans
    Period perfect parts group has been saying for a while (a couple of years) that they would soon carry repro floor pans specifically for maverick/comet, but they have yet to come through. I wound up ordering mustang pans and fender apron for under my rotted out battery tray from rock auto. Of course they're cheap Chinese stamped parts - they've got a LOT of wrinkles from being stamped, but I think with some cutting and trimming and hammer and dolly work I can make them halfway presentable
  12. MaverickMagic
    Charlotte, NC
    1973 Maverick
    Yea hopefully the guys at 3PG (Period Perfect Parts Group) will have them soon. I actually purchased a large piece of 16 Gauge Steel and fabricated my own. It was too much work as the hole wasn't too big. We're trying to stay away from the Chinese tin foil, so this was the best way to go for us. I know 3PG plans to have their own AMERICAN MADE :dance: products out soon, but its a little to late for me.
    Thanks for everyones help!
  13. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    A mid sixties Mustang pan from National Parts Depot,67 I believe,works fine.A friend installed one in my 70 mav w/ no problems at all,best you can hope for,and they are not expensive.
  14. braess
    braess Member
    Buchs Switzerland
    Ford Maverick GT 1974
    i also have the mustang pans in mine. almost no cutting or fiddling with them.
    theyre gauge 16, made in canada, but were pretty expensive to buy here in mexico.
    in us&a you should get them cheap...
    7_new_floor_driver_412410.jpg 21_boden_von_hinten_319102.jpg 22_boden_von_vorne_588980.jpg
  15. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Nice looking job on those floorpans.
