Floor Shift conv' - how to eliminate column reverse lock?
Discussion in 'General Maverick/Comet' started by Powerband, Jul 30, 2016.
  1. Powerband
    Powerband Member
    NY's \H/
    My 74 - 3 Speed On the Column - has the reverse lock to remove key.
    Appreciate info or links to info to eliminate column reverse lockout simply when converting to floor shift (T5) .
    thanks
    [​IMG] .
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You would have to take the column apart to gain access and remove the lever and locking mechanism.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    On automatics there is a rod that connects from the steering column down to the tranny. If this rod is removed and the column wired so that it does not rotate from the park position, it effectively disables the reverse lockout and allows you to start the car in any gear. I would think the manual column shift cars operate in a similar way.
