Floor Shift Swap Probs...
Discussion in 'Technical' started by Corbin Johnson, Jun 12, 2002.
  1. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Hi All,
    My computer at home crashed so I am using a school computer right now to ask you all a question. Anyway, I completed my floor shift swap, and then after starting it up (It runs now too!!!) It won't move anywhere. I am thinking that I didn't line the manual shift lever back up right with the shaft in the valve body that controls the shifts. I am going to drop the pan again tomorrow
    or the next day and get it figured out. Do you all know of any other problems/culprits it could be? Thanks for the info. Hopefully I will have my computer running soon, so I can be back "in the groove." Thanks.
    -Corbin
  2. Corbin Johnson
    New Developments......
    Hi Guys,
    Here is the scoop.... I went down to the Maverick and started it up. Then I shifted it through the gears and still nothing. Anyway, after turning it off, I unbolted the cooler lines from the radiator and no fulid came out (it was dry). Anyway, later I took of the pan and checked the manual shift linkage to confirm that it works correctly with the piece in the valve body. Everything was fine here, so now I am more confused. Since it is not pumping fluid, is the pump bad, or what? Also are there any other things that I could check. I would like to avoid taking this to a tranny shap, but if I have to I will. Thanks for any and all info. Remember, that I had this tranny apart from the engine when I did the 5.0 swap. Please hep me out here if you can. Thanks.
    -Corbin
  3. mavman
    mavman Member
    Arkansas
    what have you done to the car? Have you removed the transmission/torque converter for any reason? Also, is this a c4 transmission? For some reason, fluid is not being pumped, whether it be because of a clogged trans oil filter, clogged or dirty valvebody causing one or more valve to stick, or possibly a misalignment between the pump drive and torque converter.
  4. Corbin Johnson
    Yes, I have removed the transmission and the torque converter. I had to do this to swap trannies on my engines. Do you think that the input shaft and such are meshing with the torque converter? If not I will have to have someone take the tranny out and fix it. Thanks for any info.
    -Corbin
  5. Corbin Johnson
    Oh, yeah.
    It is a C4, and it can't be the filter because I changed it and the valve body is clean. Thanks
    -Corbin
  6. JC13
    JC13 Loyal To The Maverick
    Colorado
    1973 Maverick
    The c-4 holds a little over two gallons of fluid.
  7. Corbin Johnson
    Well,
    I am going to have a tranny shop check it out for me. I know that the C4 holds lots of fluid, but it is not pumping fluid so that leads me to think that other things are wrong. The tranny shop guy said that it is possible that when I hooked up the torque converter to the input and pump shaft that the teeth weren't lined up correctly and after starting the engine it sheared the teeth off. Anyway, the tranny would need to be rebuilt soon anyway, so for $700 I am going to have it redone soon. Thanks guys.
    -Corbin
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    RE: fluid capacity
    According to the 'book', a V-* c-4 holds 18 pints. The
    six banger version calls for 16 pints.
    Did you manually fill the converter?
  9. Corbin Johnson
    The converter had probably a pint or two in it when I assembled it. It would keep puuring out if it was really full. Anyway, I wasn't really that concerned about filling the converter because in my Mav book it just said if starting from a dry system (No fluid in converter) put in 5 quarts start the engine, shift through the gears and then fill to "Full." I followed these steps exactly but something's wrong. Next week I will take it down to be inspected and if it needs to be taken out and the pump messed with, I will just have them rebuild it and put a little shift kit in it. Which shift kit would any of you recommend. Remember that this is a street car, and I want a little snappier, firmer shifts. Nothing that will rip your head off, just a noticable improvement from stock. Thanks guys and gals.
    -Corbin
  10. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    shift kit
    B & M Shift kit, Ford even makes a shift improver kit. They are all adjustable to my knowledge.
  11. gtdrivr
    gtdrivr New Member
    Near Buffalo, NY
    hopefully 74 Mav soon, 79 Stang now
    I had this problem with a GM (choke) tranny once. The shift kit wasn't installed right. It took hrs to find that it was ALMOST right, and that a small mistake gave me no fluid flow. If it's not this, which I believe to be rare, sounds like a converter prob.
  12. phflimflam
    phflimflam Member
    Texas
    1974 Mercury Comet 4 dr, 250/6 soon to be Harshly upgraded!
    FLow Problem
    It sounds to me as though the pump front pump is bad or simply not pumping. I have seen people get a transmission installed wherein the converter wasnt fully seated before being bolted up. This can be and probably is your problem. If this is the case u may well have damaged the tranny, but not necessarily so. Id unbolt that converter from the flywheel, and pull the tranny back and make sure I had the converter seated before I ever started it again!!:D
  13. Corbin Johnson
    Update...
    I have been talking to people around here and the consensus is that the pump gears didn't mesh correctly with the torque convertor when it was put back together. This is what we were all thinking originally, but hoping that it would be something else. So the bad news is that the tranny will have to be pulled again and the gear replaced, but the good news is a family friend has a cousin that works at a tranny shop and they can get me a deal on a complete rebuild! This tranny shop is a great place. They will even make a payment plan for people who need it. Our friend has frequently sent kids with tranny problems there and they work out a plan so they can pay them back in a way that fits there income/time. That is a very rare thing these days. Anyway, now I can't wait for it to be rebuilt, then I can actually start it up again, and drive it for the first time in 6 months!!
    -Corbin
