Floor Shifter linkage question
Discussion in 'General Maverick/Comet' started by x72COMETx, Feb 23, 2014.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    Im trying to hook up my shifter linkage but it wont reach i can only shift into 1,2,D and thats all i dont think i can slide the trans back any further the linkage came off my 75 comet 250 inline 6 and now i swapped to a 302 is their 6 cyl linkages and v8 linkages or are they all the same.
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    The linkage should be the same. Adjust the linkage with the trams and shifter in the neutral position.
  3. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Is the tranny the same as the one you ran before with the floor shift 6? If not, is it from a column shift car? If so, did you remove, rotate 180 degrees, and reinstall the shift lever on the tranny?
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    The tranny is the same 1 i ran with the 6 only thing different is the engine
  5. Corbin Johnson
    Did you put in a shift kit or do anything internally?
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    No i have not put in a shift kit the linkage just seems to be to short. Can anyone tell me how to adjust it
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    Bump.... Im really having problems with this shift linkage
  8. Craig Selvey
    You have done something wrong/different as it should hook right back up.
