floorpans
Discussion in 'Technical' started by macinamav, Feb 15, 2004.
  1. macinamav
    macinamav Sr. Junior Member
    Anchorage, Alaska
    1970 Mav
    Anyone have an Idea the cost to replace floorpans (4) ? I got an estimate for $2200............mac:confused:
    Better pic later
  2. 71gold
    did you say $220. if so might not be a bad price...frank...:bananaman :bananaman
  3. Craig Selvey
    Ouch!!!
    For that kind of money....I would find an entirely rust free Maverick and have it shipped up to Alaska.
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    When I do work for others, which is seldom anymore, I quote $1000.00 to remove and weld in floorpans.
    Dan
  5. Mavaholic
    For that kind of money you can buy a compressor, air tools, sheet metal, a welder, and do it yourself. You'd still have lots of bucks left over.
  6. Jean Doll
    Palmerton, PA
    We also would charge in the area of $1000 to replace the floor pans. $2200 is way too steep a price if you ask me.
  7. macinamav
    Anchorage, Alaska
    1970 Mav
    Thanks for replies: Seems nobody wanted to do it except this body shop, everyone busy with winter insurance business. Guess I should have bought a welder and upgraded my welding skills. May have to get used to doling out dollars if I'm to finish this project. :( TY again, Mac
  8. 71gold
    mac, if you remove the seats and carpet you could cut the rusty place out yourself. it is not that much to do. could you post pics. and maybe we could walk you through this. it is only a thing. this is the place where things get done.
    i have done things to my cars that i didn't have a clue as to what to do. the folks here worked with me and we got er' done.
    give us a pic. so we know where to start...frank...:bananaman :bananaman
  9. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    Depending on how bad they are, its a pretty straight forward job. Cut it out and weld it in! Have you got any friends that have a welder and willing to teach you a little about it? Aside from the welder the tools are pretty cheap to do it yourself. You dont need Dewalt tools to do it either.....open up a Harbor Freight catalog and do a little shopping. If you plan on buying a welder, that is where you will want to spend the money. I found a great little welder for $299 on sale. Take your time, keep us posted and ask when you need advice. We arent going anywhere...there is still to much snow on the ground! :D
    ...besides, if you screw it up, then you can take it to the body shop!!
    Good luck.
  10. rx7351w
    rx7351w Member
    knoxville, tn
    74 2 door Maverick
    I just went to Harbor Frieght and bought a saws all on sale for 24.99. I to have to replace the drivers floorpan but I want to get it running first then fix the leaking cowl. I did replace the windsheild and found that all the metal around it look like new.
    I had planed on just welding in a new piece of metal over the floor with out cuting out the old floorpan just curing the rust and sealing it from the top and bottom. Will this be alright? My mav will never be a show car just something fun to drive with a lopy cammed motor.
  11. rcomet75
    rcomet75 Member
    I helped a friend replace the flor pans in his 74 Bronco neither of us are good welders but it came out just fine. We used a Arc welder, nothing special.
  12. 71gold
    m.a.v. has a mini sawall. it is neat. it has a short blade that makes it easy to handle. remember you have stuff under the car you don't want to cut (brake line, fuel line and e-cable). if you get it cut out and the pieces cut to go back in you will have the hard part done...frank...:bananaman :bananaman
  13. Mavaholic
    Only problem with this is it creates a pocket for dirt and water to accumulate causing more rusting problems down the road, especially if your car is a daily driver type. If you trim the rusted panel so your new panel only overlaps about a 1/4 inch or less, then you can either weld the bottom or put lots of paint and undercoating in the bottom lip.
  14. Ilovemavs
    Ilovemavs New Member
    Texas
    71 grabber V8 std shift
    A person in a pinch can also trim off rust and duct tape cardboard under the pans then just fiberglass from the top. Remove cardboard and undercoat it.
  15. jpollard
    jpollard Member
    Montana
    The only problem I see with the fiberglass fix is that it seems to separate from the metal after a little while, leaving more areas for moisture to get into. After going through all that, it would probably be just as easy to weld in some metal.
    my .02
    JP
