Flywheel issue with my T5 swap
Discussion in 'General Maverick/Comet' started by jski, May 24, 2013.
  1. jski
    jski Member
    Moyock, North Carolina
    I need some guidance regarding my T5 swap
    The car and motor,302, are both 1972. The trans is an 87 t-5 from a 5.0. The bell is from the 87.
    I ordered a flywheel for a 71-72 maverick (157 tooth Pioneer flywheel #163)
    The clutch from Napa (1107042) for the 87 trans.
    Only three of the six mounting bolts line up!!
    Can someone tell me what application i need to order the clutch/TOB/ PP for please. Can I use a clutch kit for the 72 with the T5?
    Part numbers would be awesome if you still have those.
    Any help would be GREATLY appreciated:huh:
    John
    Email SKI2007HD@GMAIL.COM
  2. CaptainComet
    I am a little fuzzy on this .... it has been years. Are you sure that you haven't turned it to try every possible position? Pretty sure it is assymetrical so that it can only go on one way, so that the balance weight is in the right place.
  3. mavgrab302
    Order a clutch for your 72 flywheel... the 87 clutch is meant for a 87 50oz flywheel, I think that is why it wont fit...
    JL Mav likes this.
  4. CaptainComet
    Thought he was referring to the crank to flywheel bolts ... :16suspect
    Confused .... need more coffee .....
  5. jski
    jski Member
    The flywheel mounts right up to the crank nice. The pressure plate holes dont line up with the holes in the flywheel. The flywheel is a 157 tooth.
  6. jski
    jski Member
    from a previous thread....
    2013-04-28, 15:02 #17 bmcdaniel
    Senile Member
    Vehicle(s): '70 Maverick Grabber iTrader: 8 (100%)
    Images: 4
    Quote:
    Originally Posted by mavgrab302 [​IMG]
    I just found a factory 157 tooth flywheel in the garage, will this work for the t-5 ? It's amazing what you find that you didn't know you had...lol...
    The T5 doesn't care what flywheel you use, but your engine does. And it depends on what type of clutch and pressure plate you're gonna run. Over the years I've had about every combination of clutch and flywheel on mine. Used a Long-style pp, drilled the flywheel for a factory diaphram pp, used 5.0 flywheel drilled for a Long-style, used the special CenterForce diaphram clutch for Long-style pp patterned flywheel. Always the same starter, though, the short-nosed V8 one.
    __________________
    70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, Hooker 6901s), T5Z w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
    Some people are like slinkies, good for nothing but they still make you laugh when you push them down the stairs
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    bmcdanielView Public ProfileSend a private message to bmcdanielSend email to bmcdanielFind More Posts by bmcdanielAdd bmcdaniel to Your ContactsView Gallery Uploads
    [​IMG] 2013-04-29, 15:42 #18 markso125
    Member
    Vehicle(s): 1972 maverick 2 door LDO iTrader: 4 (100%)
    Images: 5
    Quote:
    To add to this the 5.0 clutches and pressure plates are metric, where the 302 clutches and pressure plates are SAE, they almost match but they dont, so if you want to use a diaphram clutch on your engine you need to get a matching flywheel I got a ford racing one new for about $80...
    __________________
    Though I drive through the valley of imports, I shall fear no turbo; For torque art with me. Thy eight pistons and pushrods, they comfort me
    Made in America...not just assembled here
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] markso125View Public ProfileSend a private message to markso125Send email to markso125Find More Posts by markso125Add markso125 to Your ContactsView Gallery Uploads
    [​IMG] 2013-04-29, 21:30 #19 bmcdaniel
    Senile Member
    Images: 4
    They make diaphram clutches for both patterns of flywheels. The CenterForce diaphram clutch I have bolts on to an early flywheel and comes with a special length release bearing so that the original push-type release fork can be used.
    __________________
    [​IMG] [​IMG]
  7. jski
    jski Member
    If i use the pp from a 72 can i use the disk and which TOB do i use.....:cry:
  8. jski
    jski Member
    gents...a clutch setup from a 79 mustang is gonna be the one.
    79 and 72 use the 10 in while the 87 uses the 10.5. TOB are the same on both.
    napa # 1107005 for kit
    thank u for the replies
    John
  9. ChiefRocka
    ChiefRocka Father/Son 69.5 Build
    Hollister, Ca
    69.5 Maverick
    Ok....
    I know this is an old thread...but how did this work out ??
    So a 152 tooth flywheel, and a clutch kit from a 79 mustang is what is needed ??
  10. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    If you have a late model engine you need a late model flywheel (50 oz.) and clutch set up, if you have a stock maverick engine you need a n early (28 oz.) flywheel and matching pressure plate. my T5 out of an 89 mustang has the same imput shaft spine count as the three speed I took out.
