Flywheel?????????
Discussion in 'Technical' started by CDL, Mar 24, 2015.
  1. CDL
    CDL Member
    Anyone know where i can get a NEW flywheel or a good used one for my 1970 - 170 ci?
  2. Krazy Comet
    Shouldn't be too hard to find, several other models used same...
    Flywheel, 6 cyl.
    C6DZ-6375-A, 136 teeth (I verified number correct in Ford Master Parts Catalog)
    Bronco '66-74 6 cyl. std. trans.
    Comet '66-67 6 cyl. 9" clutch
    Comet '68 6 cyl. std. trans.
    Comet '71-74 6 cyl. std. trans.
    Fairlane '66-67 6 cyl. 9" clutch
    Fairlane '68 6 cyl. std. trans.
    Falcon '66-67 6-200 std. trans.
    Falcon '67 6-170 w/full synchro. trans.
    Falcon '68-70 6 cyl., std. trans.
    Maverick '70 std.trans.
    Maverick '71-74 6 cyl., std. trans.
    Mustang '66 6 cyl. std. trans. w/9" clutch
    Mustang '67-68 6 cyl. std. trans.
    Mustang '69-70 6-200, std. trans.
  3. CDL
    CDL Member
  4. CDL
    CDL Member
  5. Krazy Comet
    Welp the Ford Master Parts Catalog says differently...
    That's where I got the C6DZ-6375-A number, plugged it into net and came up with list I posted... The earlier ones('65-prior) do use a 8.5" clutch with 132T flywheel...
    Be a good idea to check yours but I'm bettin' my info is correct...
  6. CDL
    CDL Member
    if i have what your info states i would be better off, but i don't have the motor out yet thanks
  7. Krazy Comet
    The one thing stated in the link is the 8.5" clutch uses a three bolt starter and the 9" uses a two bolt, assuming that's correct should be a easy way to ID...
    BTW notice all the vehicles are 1966/newer, would appear all went to the 9" clutch at that point, probably with the introduction of Bronco.. Can't really see a Bronco with 170 or 200 having the smaller clutch...
  8. rthomas771
    '66 was the year they started using the.3.03 transmission behind the 170/200
  9. CDL
    CDL Member
    Well i definitely have a 2 bolt starter. So I'm confused on the size clutch and type trans..
  10. Krazy Comet
    Apparently the easy way is check bell housing mount to engine...
    In the pict notice the 9" bell pattern top bolts are all the way at top of block while the 8.5" are a inch or so below it... For as much as those guys should know, I'm going to say they are sorely lacking on ID/cross reference...
    If your bell mounts at top of block you have 9"...
  11. 71gold
    why do you think you need one if you don't have the old one out?
  12. CDL
    CDL Member
    Just that simple, Thanks...it's a 9 inch.
  13. CDL
    CDL Member
    Warped, and I was told most likely the WHOLE flywheel is warped and will not be able to be cut. So if true, just trying to cover my bases.
  14. 71gold
    what was it doing to think it's warped? I'm an auto. Guy so just wondering.
  15. CDL
    CDL Member
    In my case, if you don't rev the motor high enough the dash and the steering column will shake. Clutch itself is good it's just the flywheel. Just an annoyance. I think the old man who was the original owner rode the clutch. That will do it!
