flywheel
Discussion in 'General Maverick/Comet' started by cenc1984, Nov 13, 2008.
  1. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    1972 Maverick Grabber
    I put 5.0 moter with the 50oz. imbalance, changed the 164 tooth to a 157 tooth flywheel . now i have a wierd vibration. could i have bought the wrong flywheel? the vib is not bad . would the vib be bad if i got the 28oz. instead of the 50oz. the reason I am asking .My transmission guy said that I have the wrong flywheel. I need another opinion. please help ALex O.
  2. grbmaverickmo
    Aquashicola, PA
    One of my driver mavs had the wrong flywheel and the guy drove it that way. I noticed it right away but he didn`t or least didn`t admit it. If it didn`t vibrate before I would call flywheel.
  3. bmcdaniel
    What 5.0 came with a 164 tooth flywheel?
  4. ModMav71
    ModMav71 Member
    Sebring, FL
    In a word YES. The wrong balance flywheel will cause drive-train vibration and left as is can cause bearing wear or failure and other problems.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    He is probably confusing a flywheel with a flexplate...
  6. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    yes i ment flexplate
