For better or Worst?
Discussion in 'Technical' started by Bioinfomatic, Feb 7, 2008.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    For my 302HO rebuild what would be better for the rebuild the stock forged pistons or a brand new set of hypereutectic pistons? I do intend to use a 100 shot of laughing gas.
  2. Cometgt_71
    Cometgt_71 Member
    Saskatoon, Saskatchewan, Canada
    71 Comet, 2 72 Comet GT's , 73 Comet GT, 77 Maverick
    depends on how much you intend to use the gas. once in a blue moon is fine with stock, racing often -use hypers
  3. bmcdaniel
    The stock forged pistons, made by TRW, are stronger than the hypers. I won't even run hypers in a mild NA application, especially if they're Keith Black pistons. Often hypers don't like the pressure spike that nitrous causes, can make them shatter. I know some guys get away with it, most don't.
  4. tim keck
    sharps chapel,Tn
    Stock forged if the skirts aren't exessively worn.Hypers are ok,just watch your timing/fuel delivery when you're sprayin' it.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I know that some folks praise hypers, but some folks swear they are brittle.
    I would stay away from them out of an abundance of caution when using a power adder.
    Not to say that you should use the stock forged pistons either.
    They are stronger of course, but are they worn out?
    Does you block need boring?
    If so, then you can just get the stock replacement forged pistons in an overbore size.
    That is what I would do, unless the stock block and pistons are still perfect.
  6. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    The block and pistons are fine....Well I guess I just answered my own question then, since the factory forged pistons are stronger and are in good condition I should use them.
  7. don graham
    Unless there's a problem with the stock pistons, they should be stronger.:)
