for the ppl who have a t5 in the car drive shaft
Discussion in 'General Maverick/Comet' started by classic ccg, Mar 29, 2012.
  1. classic ccg
    ringgold GA
    72 maverick
    where did you get your drive shaft and how long do i need?
  2. Earl Branham
    Lugoff, SC
    I used my stock drive shaft without modification. I did have to put a new yoke on the trans end to fit the T5.
  3. classic ccg
    ringgold GA
    72 maverick
    thak you buddy i hope to it runing by the time you guys come up:drive:
  4. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    I put one in mine and used the stock driveshaft with no modifications. Was an automatic and converted it to T5.
  5. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Used a stock 5.0 Mustang shaft removed the 4 bolt flange,bolted right in.
  6. Streamliner
    Streamliner Member
    Same here:thumbs2:
  7. classic ccg
    ringgold GA
    72 maverick
    my car is a 3 on the tree and i had the 170 ci
  8. bmcdaniel
    I had a 3" custom made by The DriveLine Shop. All new parts and spin balaced, $200 delivered to my door.
  9. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    I have a stock 1990 5.0 Mustang drive-shaft. Way stronger than the stock one. Exactly the right length.
  10. CaptainComet
    Interesting replies ... in the article that they just did in Car Craft, they cut the stock Mav driveshaft 1", going from a C4 to the T5.
    You want to be sure to have some room for the yoke to move into the tailshaft as the suspension moves up and down. You never want that to bottom out, but don't know the spec off the top of my head.
  11. injectedmav
    injectedmav Member
    Georgia
    I cut mine as well. I don't remember how much but I'm sure it was around 1"
  12. jb70grabber
    jb70grabber Member
    East windsor ct
    1970 maverick grabber 306 gt40 x heads and cam t-5 5 speed 8.8 rear 17 bullitt wheels also 76 low 22k 2dr undergoing restoration
    i used a stock 5.0 mustang driveshaft which worked well with the stock ride height with a 6 3/4 rear end, but when i lowered the car and installed the 8.8 i had to have 1 inch removed from it to give the yoke enough clearance so not to bottom out against the tail housing on the transmission
  13. bmcdaniel
    I set mine to 3/4" out with the car sitting on the ground. A bump will move the rear upward and push the yoke into the tranny.
  14. Jamie Miles
    I had to use a stock fox body 'stang shaft when I converted over to the SROD (same dimensions as a T5) The Mustang shaft was an inch shorter then the Mav shaft. The yoke was basically bottomed out in the trans with the stock Maverick shaft.
