For Those With 4-Wheel Discs...
Discussion in 'Technical' started by Maxx Levell, Aug 16, 2010.
  1. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    I have an Aerospace rear disc setup that should arrive Wednesday...you guys that run rear discs...did you have to install a proportioning valve to adjust the bias to the rears? Or did you just install them using the factory prop valve?
    Thanks...
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    I installed a valve after the factory valve , but you could probably run a four wheel disc brake factory one .that is if you can find one
  3. 71gold
    i run straight from the MC to the calipers...i let the larger rear tires do the ...bias.
    ...:bouncy:...
  4. chirt
    chirt Carlos Hirt
    Massachusetts
    x2!(y)
  5. Earl Branham
    Lugoff, SC
    I have a Wilwood prop valve/dist block and backup lights all in one unit. Seems to work very well. Haven't had to adjust the rear bias yet, worked great right out of the box.
  6. cjtorinoman
    cjtorinoman Member
    chesapeake va
    I run all Wilwood 4 wheel disc and there master cylinder and no valve at all works better than anything else I have found :thumbs2:
  7. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Cool...thanks guys. I guess I'm just going to try it straight up at first and see how it goes...brakes didn't arrive until late today, so maybe I can pick them up tomorrow and start putting things back together over the weekend.
