ford 302 exhaust
Discussion in 'General Maverick/Comet' started by x72COMETx, Apr 16, 2013.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    ok so im building a 302 to replace my 250 and i have the stock 302 heads and cam and i went and drove my brothers comet and the sound of the exhaust is perfect and he has shorty headers with flowmaster 50 series and im going with longtube headers with 40 series and i asked if mine could sound like that and he said no because he has 351 heads and i was wondering if any body has the setup that im going with and how does it sound thanks
  2. Dave B
    The cam would have more to do with the sound.
  3. scooper77515
    Long tube headers. Flowmaster super 44 which are a little louder than regular 40s.
    The lopey idle is due to the cam. Engine specs are listed below.
  4. Mavman72
    You can get a stock engine to sound good with the right mufflers/pipe diameters and long tube headers. If you want it to sound like a hopped up engine...You have to hop it up. The sound has more to do with cam choice and compression ratio than the actual heads being used.
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    As the others have said sound has more to do with the cam, but I will say mine sounded a lot louder after swapping to trick flow from e7's. Same tone just louder.
  6. scooper77515
    Cam only works if heads allow it to flow.
    Exhaust can make the sound without heads and cam.
  7. Dave B
    Sure, cut the mufflers off.
  8. bmcdaniel
    And pull one spark plug wire off...
  9. 71gold
    you have a vid of the sound a motor makes with...no heads or cam...:huh:
  10. bmcdaniel
    Yeah, it's an electric car. Makes a kind of purring noise.
  11. rthomas771
    It makes a slight scrapping sound...kinda like pistons rings dragging on a cylinder wall. :yup:
  12. scooper77515
    I actually drove mine around stock with just the muffler cut off. Wasn't really loud, but sounded pretty good. Then used long glasspacks in side pipes and everyone loved the sound.
    That was bone stock with a 4-barrel swap. That is what I mean by "no heads or cam". But you all know I mean head or cam upgrades...geez.
  13. Krazy Comet
    There you go... Better heads = more HP due to increased flow, exhaust will be louder... Cam will control the pumping characteristics of the engine, which mostly effects the type of sound...
  14. MrP
    MrP Member
    1970 Maverick 302
    People like the sound of my long tubes, true duals and flowmaster 40's with dumps....I don't. I think some slp loudmouths will wake the neighborhood up ;)
  15. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    http://youtu.be/Q2DRyQGEjU0
    This is mine with new dual exhaust hooker headers,40 series mufflers, 2.5 in tubes dumping at the axle
