ford 302 pricing help
Discussion in 'General Maverick/Comet' started by runeking40, Aug 20, 2010.
  1. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    what would be the best price to sell my 1979 ford 302 at it doesn't look the greatest but what old engine does and ir ran when it was pulled out of an ltd
  2. PaulS
    You won't get much more than a core price for it unless you can prove some reason for more money. Cores in this area go for $75 - $150.
  3. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    well i am trying to sell for 125 and no one is buying and it comes with flywheel alternator i just dont know why no one is buying
  4. PaulS
    used engines are a hard sell - you need to find someone who wants to build one.
  5. Craig Selvey
    You also need to give it more than a few days.
  6. Farmall
    Farmall Member
    New Mexico
    1972 Grabber & two 69.5 Mavericks
    I sold my 1975 302 two barrel out of a Mav for $150. It started and ran great with no smoke or noise. It was complete as pulled, with carb, alt, brackets, oil pan, fuel pump, starter, and flexplate. Ready, to bolt in and run. I included pictures of it running in my ad with pictures of it holding oil psi, vacuum guage readings and included documented cyl. psi compression test results. Even with that, it took a month or two of weekly craigs list listings to get past the "I want it, can you hold it for me" respondses that were always no-shows. As was said before, someone will be looking for a builder. I sold the 72 302 out of a Comet for $75, because it did not have a carb or dist. so could not warrent it would run.
    There are lots of late model roller cam 5.0 HO long blocks around here for about $150, so it is hard to get more than that for an older 302 other than for a restore or early block builder.
    Good luck, Farmall
