Ford 8" differential Upgrade
Discussion in 'Technical' started by Mav06, Jan 2, 2011.
  1. Mav06
    Mav06 Member
    El Paso
    1970 2Dr 200 c.i I6
    Hello, all I currently have a 70 maverick with an 8" 4 lug rear end. I'm trying to upgrade it to a 5-lug. I've read on another post that you cannot interchange just the axles. What is the best way to go? Should I rebuild the differential with all the necessary parts to do what I want or should I just look for a donor car? Thanks!!:tiphat:
  2. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    I have a 8" 5 lug unit. I will sell for $200.00 plus shipping.
    PM me if interested.
    Rick
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Find a Granada/Monarch 8" rear.
    All are 5 lugs, and in an I6 car, you just might find a 9" rear.
    The computer tells the yards I know to sell for about 85 bux each.
    I got a 9" that way. The online network said the rear was worth 85 bux, so that is what they charged me. The 9" came from an I6 Monarch.
  4. 3154tm
    3154tm Member
    what's the difference in width between the granada/monarch and the maverick axle?
  5. rthomas771
    I haven't measured a Maverick but the Granada is 57-3/4" outside drum to outside drum.
  6. ratio411
    ratio411 Member
    Pensacola
    Less than 3/4" added per side.
    Roughly 1.25" wider overall.
    Only enough to worry about if you are running wider tires/rims that you have dialed in perfectly for the stock width.
    Granada rears are same width as 64-66 Mustang or 57-59 Fords...
    They came with 8", 9", and 8.7" rears.
  7. ratio411
    ratio411 Member
    Pensacola
    Maverick is 56.5"
    Edit:
    There is NO other difference in the rears.
    They are a DIRECT bolt in.
  8. predfan2001
    Are you sure it's an 8"? My 70 came with on of those junky 4 bolt rearends that had a cover. 7 1/4"???
  9. rthomas771
    70's came with either a 7.25" or 8".
  10. brainsboy
    brainsboy Member
    Tampa
    If all you want to do is switch to 5 lugs and keep the same rear end, then I believe you may be able to just have 4lugs wheel beaqrings pressed onto the 5lug axles.
  11. ratio411
    ratio411 Member
    Pensacola
    No.
    Won't work.
  12. spxer
    spxer Member
    Raleigh NC
    a 4 lug 8 inch???? i had always thought if it was an 8 inch it would be 5 lug anyway??
  13. darren
    Nope lots of 4 lug 8" came factory. My car had one.
  14. Jamie Miles
    The axles are different diameters, won't work.
    Every '71-'72 Maverick built that came with a 6 cylinder came with a 4 lug 8 inch.
  15. maverick maniac
    maverick maniac Banned
    owensboro ky
    donor car or I have a set of 4 lug axles that have been redrilled to 5 lug pattern .
    pull yours out put these in and you will have 5 lug rear
