Ford debuts Blind Spot Mirror on '09 Edge
Discussion in 'Ford Industry News' started by Mav.bot, Aug 6, 2008.
  1. Mav.bot
    Mav.bot Member
    Filed under: Safety, Crossovers/CUVs, Ford
    Click above for high-res gallery of 2009 Ford Edge
    The blind spot has been a consistent safety issue for automobiles since before the invention of the C-pillar. Some automakers have recently tackled the problem with complicated warning systems that beep when your blind spot is about to cause an accident. Ford is taking a different but no less effective low-tech route with the introduction of its Blind Spot Mirror on the 2009 Edge. The technology behind the Blind Spot Mirror is simple; it's little more than a secondary convex mirror in the top right corner of the traditional side mirror that gives a clear view of what before was only visible by craning your neck left and right. We've seen this type of tech used before on aftermarket mirrors for towing applications, but it makes just as much sense on an unencumbered passenger vehicle.
    Ford came up with the mirror in response to its own customer research that showed drivers were 76% more confident behind the wheel when using the mirror. The overwhelmingly positive feedback has led the Blue Oval to introduce the Blind Spot Mirror across its lineup as quickly as possible, starting with the 2009 Edge. Check out Ford's official presser after the jump and view the '09 Edge in our gallery below.
    [Source: Ford]Continue reading Ford debuts Blind Spot Mirror on '09 Edge
    Permalink | Email this | Comments
    More...
  2. Jamie Miles
    My grandpa has been putting those little round stick on mirrors on his mirrors for like 40 years. Nice to know the automakers catch on so quickly. :rofl2:
  3. Dave B
    Yup, if you've ever driven a full sized van for a living, someones always added one along the way.
