Ford maverick dash lights
Discussion in 'Technical' started by That73mav, Sep 7, 2024.
  1. That73mav
    That73mav Member
    Cottonwood Alabama
    1973 ford maverick
    Is there any way to test out the dash lights (Oil, Temp, Alt, and Breaks) ?
  2. bmcdaniel
    bmcdaniel Senile Member
    When you turn your key to the START position the idiot lights turn on for a few seconds so you can do a light check.
  3. That73mav
    That73mav Member
    Cottonwood Alabama
    1973 ford maverick
    I’ve tried it and it won’t work, I’ve seen them flash 1 time when starting the car
  4. bmcdaniel
    Ok, so if you saw them flash they must be working.
  5. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    They should stay on as long as the key is in the "Start" position. If your car has an automatic transmission, put the shifter in gear and turn the key to the start position. The Oil, Temp, and Brake (and maybe seat belt) lights should light up, and not go out until you release from the start position...
    Krazy Comet and Powerband like this.
  6. That73mav
    That73mav Member
    Cottonwood Alabama
    1973 ford maverick
    Still nothing
  7. TeeEl
    TeeEl Senior Member
    Colorado
    Well either the bulbs are burnt out or there is a bad connection (or no connection).
    Are your Oil and Temp sending units hooked up? 'Might be time to pull out the instrument cluster and have a look at things...
    mojo likes this.
  8. Krazy Comet
    Possibly the "prove out" circuit in ignition switch has failed.
    It's only purpose is power the warning lights when starting to confirm bulbs are working.
    The oil pressure light should illuminate with switch on, engine not started. If not, the oil pressure sender has likely failed. Can ground it's connector to test bulb circuit.
    TeeEl likes this.
