ford maverick making a sqeeking noise can any1 help
Discussion in 'New Members Forum' started by trev79, Sep 29, 2009.
  1. trev79
    trev79 New Member
    doncaster
    ford maverick
    its making a noise like a really bad flat tyre,which the tyre is fine then the car starts sqeeking really loud does any1 know what the problem can be
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    does it do it when you drive or when you parked? squeeking can be from a belt. I don't know what you mean with a flat time sound.
  3. trev79
    trev79 New Member
    doncaster
    ford maverick
    as soon as i pull off from parked position the sound of flat tyre or something stuck to the tyre starts making a very loud noise like when u have a blowout,then this loud sqeeking noise from the whole car becomes very noisy like a whineing noise and when u slow down to brake it makes a clonking noise
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Get under the car and compare the 2 sides. Something sounds like has come loose.
  5. Craig Selvey
    Sounds like upper a-arm bushings making noise. Very common problem on a Maverick.
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
    normally i agree with craig but your second description sounds more like U joints or a front wheel bearing. what part of the car does it sound like it is coming from? if it is one of the front tires then it is probably that hub bearing. if it sounds like directly under the seats area then it is the u joints....
  7. Mavman72
    Sounds like you have a brake shoe flopping around in a drum.
  8. trev79
    trev79 New Member
    doncaster
    ford maverick
    the loud noise like the flat tyre seems to be coming from the passenger side,i would say the whineing noise is coming from the front of the car and its seems to stop onall the time and its getting really embarrassing driving it,the steering seems a bit light now aswell
  9. 72MAVGRABHER
    Roanoke, Va.
    (y) the suspension squeaks...
  10. justin has a 74
    kentucky
    get some glasspacks to cover up the sound:rolleyes:
    it could be a million things
  11. sierra grabber
    northern nevada
    if you go bounce that fender up and down and do not hear the squeak then jack it up and spin the tire to see if you hear it. if you do check the brakes and the bearing before driving anymore...
