ford pcm gurus please help
Discussion in 'Technical' started by Mustangnut, Nov 6, 2014.
  1. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Posting up markings I found on the pcm I bought. Supposidely a 90 gt mad car......the codes worry me.
    Tag is gone.
    Markings are:
    E4lb-14a459-b
    That's on the plastic where the harness would plug in.....
    E4 to me means 84.....uh oh
  2. Krazy Comet
    That's the engineering number for plug, about all EEC-IV PCM have same number...
    Without the tag, no idea what it's for....
  3. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Phew so at least there is a chance he is honest. He said it was off of his car.....both the harness and pcm
    Some how I can't find any o2 sensor plugs on the harness???
  4. Krazy Comet
    The o2 sensor harness is separate, plugs into a round 4pin connector at rear of engine...
    Does harness have a MAF connector??
  5. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Yes I believe so. Its got a grey cap on it and located next to the alternator plug.
  6. 71Mavrk
    71Mavrk Member
    Nevada
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    The casting number does indicates 1984, but that does not mean that that part was not still used in 1990. The stamping could also just be for the plastic harness connector, and not the ECM itself. ECM base numbers are usually 12a650 not 14a459.
  8. Krazy Comet
    There is a way to approx date any electronic device, from date code on components...
    Here is pict of PCM in my '93 Lightning(sold)... I was focusing on leaking capacitor(that I replaced) but notice IC in lower left bottom, last line ends with 9240.. That is year(1992) and week(40th) the part was produced, impossible to been installed in say 1990... Not all major parts will have dates but probably at least 50% will be dated...
