Ford Toploader 4-speed swap
Discussion in 'Transmissions' started by seth, Jun 6, 2010.
  1. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    I have been thinking about doing a manual transmission swap and was trying to find out everything that would have to be done to my 69 c4 column shifter maverick. And also what are the most likely vehicles that i would find a toploader and clutch petal assembly of this purpose
  2. maverick75
  3. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    Is there other pedal assembly that can be used for the swap? and what other cars are the toploaders in that have the correct output shaft langth?
  4. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    o,h and will a Ford Toploader 4-speed fit in the 69 trans tunnel?
  5. rthomas771
    The Toploader is smaller than a C4
  6. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    so it should fit fine them
  7. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    oh and whats a good/average price that i should be looking?
  8. mav1970
    I had some clearence problems with my linkage rods but I tweaked the crossmember and the upper cross brace and all was well.
    I'm also using a Hurst V-Gate shifter and that may be a problem only to that shifter.
  9. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ok thanks i have been thinking of doing this swap but i need more info then just whats on the tech article
  10. 302-72-mav
    302-72-mav Member
    sactown CA
  11. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    how much harder is it to get the clutch installed isn't it hydraulic? and what about the drive shaft can you find one with the correct length without having it cut and rebalanced
  12. mercgt73
    I originally swapped a toploader in place of my C4. It was definitely fun to drive.
    I still have all my four speed stuff that I will not be putting back since I am going to use a TKO instead. PM me if you want to stop by and look at what I have (and possibly take it home). Im over on the eastern shore. You can't beat free shipping. :thumbs2:
  13. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    I also had to clearance the upper brace on my car for the shift linkage and I am using a competition plus shifter.
  14. tody
    tody Member
    cologne, germany
    do you have any pictures of that?
  15. mav1970
    Thomas, your 72 may be fine as it has the larger tunnel - the 69.5/70 Mavericks had the smallest transmission tunnels. :)
