They need some work. I am getting an estimate from Just Dashes. Haven't seen many of these around. http://homepage.mac.com/dmhines/PhotoAlbum12.html
Sweet ... The "Work" you are refering to , Are you looking to get rid of the wrinkles ? If so this is something that can be done easily as long as the material is not brittle ... Just seperate the material from the backing CAREFULLY. Then use a hairdryer and a hot glue gun . First heat up the material, pull it straight then glue it down . Start from the middle and work your way out. The corners are a little bit tricky but you can streach it enough to cover without laps ... Worked for me ... I did the panels on my galaxie and after the dye job they looked like new ....
I have a set for my orange mav. They are very hard to find. The ones i have are the only ones I have ever seen. My came out of a body shop where they had been stored for 20 some odd years. They had saved them off of a wrecked parts car they used back in the early 70's. They had just never used them. These babies are nice.
??? How do you take them off without wrecking them????Never worked up the gahonees to risk ruinging mine...:confused:
