Frame Connectors ?
Discussion in 'General Maverick/Comet' started by John W, Oct 15, 2013.
  1. John W
    John W Member
    Walkerton Ontario Canada
    1932 Ford Roadster Hot Rod 1977 Maverick
    What is the most popular make of frame connectors that guys are using? Any forum member making them? Working on a 1977.
  2. Mavman72
    Either alstons or chassis engineering connectors. There is a fella here on the forum...(toporanger) Who has a set in the works, along with a very nice custom belly bar and export brace that are available now.
  3. scooper77515
    A member that used to frequent here made me a set out of galvanized pipe. Just a couple of slight bends, and cut the ends at an angle.
  4. Dave B
    Sorry John, I had a busy weekend, and didn't get a chance to email you. I have the Chassis Engineering weld in, ones. They seem to fit well, but fit better, with some trimming.
  5. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Agreed:thumbs2:
  6. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    I used Chassis Engineering Sub Frame Connectors.
    I am going a different route as far as mounting points.
    I am going to put a cross member in the back with a rear trans safety loop kinda like the picture below
    And with the picture above, I am going to build brackets for a lower link mounting spot.
    Then going to build "frame" extension for the Top link (doing a triangulated 3 link)
    Sorta like this pic below
  7. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    and to make a side comment. I got them damn near identical mounting spot. I think I was off 1/16th of a inch both forward, and side to side (based off of rear frame rail). Was pretty proud, I measured once, and cut once lol...
  8. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Lzoesch What size square tube did you use?
  9. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Think it was 2x2 or 2 1/4 x 2 1/4...
    I should be home (currently in Louisianan) in a week or so and could give you the exact number...
  10. John W
    John W Member
    Great to receive feed back from guys who have "been there, done that" Thanks guys.
    John
  11. Cruzin Illusion
    1972 Grabber
    Here is some inspiration:
  12. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    nice... you have more pictures of your build?
  13. mercgt73
    mercgt73 Member
  14. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    While I'm assuming most people using sub frame connectors are building race cars or strong street strip cars, I've often wondered if adding them to a purely street driven car woulkd stiffen up up the car and reduce any groaning and/or creeking from unibody flex over rough road.
    Opinion/experience?
  15. John W
    John W Member
    "A picture is worth a 1000 words" -- Thank you -- Cruzin Illusion for sharing yours.
