Freebie update
Discussion in 'General Maverick/Comet' started by Russ, Dec 9, 2003.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Well I put a new starter on (thanks Steve)but it wont turn over with the key. Hazard light flash, but no turn signals, wipers, radio or headlights. Dome light comes on with the door but not with the switch. I jumped the starter seloniod, and it turns over really fast, but no spark. I used a jumper wire between the batt and coil, but then the Battery ran down. So maybe tomarrow with a fresh charge on the battery I'll try it again. The fuse box is corroded pretty bad, so I guess thats the main elec. problem. If I can get it running I will be able to put it in my garage to start some serious cleaning. Stay tuned... Russ
  2. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    I have no doubt that most, if not all, of your electrical problems are with the fuse box. I had a few problems with the Stallion and it was due to the corrosion that seems too common with the fuse boxes. I cleaned each blade with a Dremel and used electrical contact cleaner after. The fuses were replaced for general principals. All of my problems were solved then. You can use some dielectric grease (spark plug grease) on the fuse tips sparingly to help keep down the return of the corrosion after the cleaning.
  3. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    I agree with wes its gotta be the fuse box
  4. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Thats what I figure. I just want to be able to get it started so I can get it out of my dads driveway and into my garage. BTW Ford (enginering dept) That was a great place for the fuse box. Russ
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    hahaha
    I had that same thought (plus a few explatives) the other day while I was tracking down a rookie wiring mistake I made.
    Put three dash light fuses in before considering the possibility that I (who is of course without fault:p ) may have made an error.
    :slap:
  6. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    i agree about the fuse block, what were they thinking!! but the position in my mustang II's is more of a PITA!
    i cant remember if you told me how long it has been sitting, did you do anything with the carb yet? im sure its going to be very dry.. but im sure you probably been down that road already..
    also is the car points or dura spark?
    glad that starter is working for you.. keep us updated..:clap:
  7. Mavaholic
    If you jumped 12v to the coil and then jumped the solenoid you should get spark. 73's still had points. Either file and regap them or spend a couple of bucks and buy a new set. A bad condenser will also cause no spark.
  8. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    I did have spark at the points, But by the time I got that far, the battery went dead. I can smell gas at the carb(really stale gas) but it is pumping. The previous owner said the car sat for two years. It was in a really run down garage(the doors of the garage had to be pried out from under the roof just to get the car out). The windows were rolled up tight and the was about 1/2 inch of mold and mildew on the carpet. I Frebres'd the hell out of it for now. It has surface rust on everything. I only have a one car garage, so when my folks go to FL for the winter, I can put my 74 in their garage. Then I can bring the 4 door to my place. (Dear Santa I want a bigger garage). Stay tuned. Russ
  9. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    russ you can put your 74 in my garage. i promise... me n todd won't even look at it
  10. badmav70
    badmav70 Member
    pittsburgh, pa
    better get yourself some fresh gas.. it will help greatly in the long run.. my 6's will run on just about anything but they really don't like old gas :D
  11. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Well I got it to run and took a drive around the neighborhood. It drives nice (except for the brakes) Still haven't got it cleaned up yet. Here's apic. of what it looked like on the way home. Russ
  12. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    another
  13. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Last one. I did get all of the hub caps. That is just dirt on the trunk no rust up there, just in the bottom of the rear quarters. Russ
  14. scott
    scott Member
    new jersey
    HEY!!!!!! that's my house!!!!!! with the red front door!
  15. Craig Selvey
    My 1973 4-door looks very similar....including the AAA sticker that was on the back.
