freeze plug location on 302
Discussion in 'General Maverick/Comet' started by bLaH_hA, Feb 20, 2010.
  1. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    :huh:i am pretty sure i blew a freeze plug. i put my mav in park and bam all the water drained out toward the back of my engine. i need help
  2. 71gold
    put some water in and see where it's comming out...:yup:
  3. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    i have water in the car now but its not leaking while its not running. only whenever the car is run or has ran
  4. comet416
    comet416 Member
    michigan
    1970 maverick
    need to start the car for a little bit if the block has drained your water pump will have to assist the water to get the block and hoses full. sounds like a heater hose if it only leaks under pressure a soft plug it wouldnt matter if it is running or not.
  5. 302-72-mav
    302-72-mav Member
    sactown CA
  6. PaulS
    There are soft plugs on the heads.... one on each end, I believe. The rear ones are nearly impossible to get at with the heads in place. Start the car and watch for the water and then trace it back to the source.
