...friends and cars...
Discussion in 'General Maverick/Comet' started by 71gold, May 9, 2012.
  1. 71gold
    road up to Atl. and picked up Jeff. we then went to Earls to help him do some trouble shooting on his car.
    ...316 miles round trip...
    we got his car running ...:yup:
    Earl took us out to eat...thanks for lunch...:Handshake
    "A Large Time Was Had By All""
  2. don graham
    That's what friends are for.:bananaman
  3. mojo
    What was the problem keeping Earl's car frm running?
  4. Mavman72
    Yes yes...Inquireing minds want to know...:bouncy:
  5. Earl Branham
    Lugoff, SC
    Appeared to be an ignition switch problem, but who knows. We put it back together and it worked. We tested and took voltage readings before starting it up. Still good, no problems so far.
  6. mojo
    All u did was replace the ign switch? Glad u got it fixed.
  7. Earl Branham
    Lugoff, SC
    Everett; Didn't replace it, just reinstalled the same one, after taking a look at the connections, etc. Strange!!! BTW, you coming to the Roundup this year?
  8. mojo
    I hope to make the RU this year. If all goes well I plan on attending. I need to make my reservations. Im going to do it today. I need to look at my ign. switch - the car will run in the accessory position.
  9. Earl Branham
    Lugoff, SC
    Everett, change it out before it bites you. Mine cost me two distributers and a few coils before we found what it was. See you in July!
  10. 71gold
    are you saying...when you turn the key through off to acc. it doesn't shut the engine off?
    do you want Jeff and Earl to come up and take a look at it for you?...:tiphat:
  11. doncomfort
    chillicothe oh
    Mine does that too sometimes. I used to pull the coil wire to shut it off. I have installed a switch in the ignition wire so I dont look stupid turning the car off. Hasn't done it awhile, any ideas? I should tell you I dont have the factory ignition switch anymore, I have a universal switch on the dash.
  12. 71gold
    there's one idea...:D
    what all did you...bypass...to install that?
  13. Earl Branham
    Lugoff, SC
    Sounds like a soleniod problem. I had mine do that once, went thru 4 switches at an Autozone before I got one that worked. BTW, why don't you come with us Frank, Everett lives in Chicago!
  14. 71gold
    that's why...:yup:
  15. doncomfort
    chillicothe oh
    I took the positive wire from the coil, ran it to a switch on the dash, then back. I suppose it can also be an anti theft device, lol.
