from manual steering to power
Discussion in 'Parts Interchange' started by maverickdad, Feb 2, 2005.
  1. maverickdad
    maverickdad Member
    Martinsville Indiana
    1974 maverick
    I am changeing my 74 mav from manual steering to power steering. I have parts off of a 76. Problem that I am having is that I need the center link. Also the idler arm on the car has the stud coming off of it. I need one that has a hole instead of the stud to do the hook up. Can anyone help me out with this? Also I am going to power brakes. I have the power brake system off of a 76. The problem there is the mounting of the power booster. Is there a plate that I need? How can I solve this problem?
  2. Craig Selvey
    I have all the parts to put a power steering on your car if you are interested. You know where I live. :)
    On the brakes....there is a mounting bracket that you need for the power booster. I don't have any...But I can show you what it looks like.
  3. Mavaholic
    For the power brake set up you need the whole pedal assembly along with the mounting plate.
  4. maverickdad
    maverickdad Member
    1974 maverick
    I have the pedal assembly. The only thing left I need to find is the mounting plate for the booster. Anyone have one?
  5. grbmaverickmo
    Aquashicola, PA
  6. Dpop74
    Dpop74 New Member
    Cleveland Ohio
    1974 Maverick
    I could use some of your old parts
    A company called autokrafter may have the parts your looking for. Also I sent you an email but I wanted to ask here as well if you have your old parts I could use your old Pittman Arm. It looks like an L but it should bend down about two inches. If your part looks like that please let me know if you want to sell it my email is darrell.popovich@sprintnet.net thank you.
