front bumper
Discussion in 'General Maverick/Comet' started by 73curtis, Feb 25, 2015.
  1. 73curtis
    73curtis Member
    ohio
    need to get a 72 front bumper off to get rechromed, how much is involved in removing it?
  2. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    I found it easiest to drop the front valence first, which is six bolts and disconnecting the wires to the turn signals then it is four bolts to take off the brackets from the body and then six bolts to get the bumper off the brackets for a Maverick
    Paul Masson likes this.
  3. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Given that you are in Ohio, I would recommend soaking the bumper bolts with PB Blaster or other penetrating oil and let it soak in for a few days.
    Craig Selvey likes this.
  4. 73curtis
    73curtis Member
    ohio
    are the turn signals mounted to the bumper or the valance panel, its a maverick, just trying to find out what to expect, sounds pretty simple, plan on taking it off when it gets a little warmer (no heat in the garage and there's not much room without opening the garage door and moving it back , thanks
  5. JL Mav
    Douglas county NV
    Four more small bolts to take the turn signals off the bumper, forgot that since I went to a 74 grill long ago, honestly with hand tools and bolts that don't need to be cut off it should take less than 45 minutes depending on the beverage breaks.
  6. 73curtis
    73curtis Member
    ohio
    thanks for the input
  7. Craig Selvey
    We are in the rust belt.....nothing is that fast. :D
    Be very careful with the turn signals. It is easy to twist and break the bolts off because they are small. I would remove the bumper first, then take a wire wheel and clean up all the threads on the back side of all the bolts on the bumper as well as the turn signals. Soak with PB blaster....then give it a few days to a week to work its magic.
  8. JL Mav
    Douglas county NV
    Didn't think of that, I'm spoiled with not much rust in the Great Basin.
  9. 71gold
    here is a pic. of the early lights and where they mount to the bumper.
