front disc brake question
Discussion in 'Technical' started by JHodges, Mar 27, 2009.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I am going to put the front disc brakes on my maverick tomorrow. I was wondering if there was a specific torque setting or just tighten them hard as you can
  2. mean_maverick
    good and snug will work (y)
  3. bartikus
    bartikus Member
    salt lake city, ut
    what are you trying to tighten on the disc breaks
  4. JHodges
    JHodges thumper
    Dora Alabama
    where it bolts to the a frame and tie rod
  5. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    sounds like upper and lower ball joints and tierods. Ball joints as tight as you can get but remember to install cotter pins. tierods are only 3/8 stud usually so about 30 lbs of torque on a wrench. Again put cotter pins in. You may have to tighten or loosen to aligh holes with the groove in the castle nuts.This is what i do and have never had any problems, Knock on Wood:tiphat:
