Front disc brakes
Discussion in 'Technical' started by Tannersg1, May 11, 2015.
  1. Tannersg1
    Tannersg1 Member
    Classified
    I'm in the process of going from drum/drum to manual disc/drum brakes. Is it nessecary to swap out the master cylinder and combination valve? Thanks!
  2. Craig Selvey
    I would at least swap out the master cylinder. You will want the larger reservoir that the disc master cylinder provides.
    Crazy Larry and Tannersg1 like this.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I echo what Craig said.
    Tannersg1 likes this.
  4. 71gold
    I ran the drum/drum M/C and prop valve with my drum/disc swap...no problems...:thumbs2:
  5. Tannersg1
    Tannersg1 Member
    Classified
    That's what i'm going to do and if i have issues I'll just swap out the master cylinder!
    71gold likes this.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    So did I. 'Just gotta make sure your rear wheels don't lock up too quickly. Larger rear tires help to reduce this as well.
    71gold and Tannersg1 like this.
  7. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    do they make a disk/drum MC for the maverick? or do i need to get one for a different car
  8. Paul Masson
    1971 Grabber
    Front disc was standard on ALL 76 and 77 Maverick and Comets, regardless of other options. Just order a (most likely Manual) master cylinder for a 76 or 77. I bought my stuff from Rock Auto. They have lots of them...
    71gold and Craig Selvey like this.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    '74 and '75 was optional for front discs. I have a '74 disc/drum M/C on my '73.
  10. injectedmav
    injectedmav Member
    Georgia
    The only issue I had was that fluid displaced with brake pad wear would empty the reservoir before the front pads needed replacement. Just requires periodically checking the fluid and emptying out the reservoir or opening the caliper bleeders when you push the caliper pistons back in for a brake job. Shouldn't pose a problem
    75 was standard disc with optional power assist. 74 was optional disc or drum
  11. t.ramsey
    t.ramsey Member
    austin,tx
    both
    My '75 came with manual drums all around.
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yeah, they didn't become "standard" until '76.
  13. rthomas771
    My front disc were dragging so bad with the drum brake master cylinder that I had to crack the bleeder to be able to spin the wheel on the spindle. Swapped to disc master and it solved the problem
  14. Paul Masson
    1971 Grabber
    This is what I am running also. My lines were in excellent shape, so I was able to grind the flares off the ends with a bench grinder, swap fittings and then re-flare. Other than the fittings, it's a bolt-in swap.
