Front disc SWAP GRANADA brake setup.
Discussion in 'Technical' started by Evening, Sep 20, 2011.
  1. Evening
    Evening Member
    Eastern Europe
    '75 Comet [2dr]
    Hello
    I need a questions:
    I can buy this stuff for brake setup:
    - calipers
    - brake pads
    - rotors
    - spindles
    1st question:
    Let me know what i still need for this? [I got 4 power drums]
    2nd question:
    This setup will be fit for magnum 500 wheels?
  2. 71gold
    do you get the mounting hardware (bolts)?
    ...dust shields...new rubber brake lines...wheel bearings and seals...(paint) :D
    ...Frank...(y)
  3. baddad457
    I would completely go thru the front suspension while you're at it too, new ball joints, upper and lower arms, tie rod ends, new spring pads, etc. Unless this has all been done already. No use in increasing the stopping power, only to combine it with worn out suspension parts.
  4. Evening
    Evening Member
    Eastern Europe
    '75 Comet [2dr]
    Let me know where i can buy this parts I need to also replace them.
  5. baddad457
    There are several venders for suspension rebuild kits, but unfortunately I don't know their names right off hand.(someone else can chime in here) The easiest way to do it is to replace the upper arms with new ones as they're sold complete with new joints and bushings, just bolt emn on and go. Ditto for the lower arms. These arms weaken with age so it's better to replace with new ones. You'll pay a little more, but this way is a whole lot easier than trying to replace just the ball joints and bushings in old arms.
  6. rthomas771
    ...:yup:...
    Also trying to remove the UCA shaft 9 times out of 10 you will wipe the threads and end up buying a new UCA anyway
  7. Moneymaker 1
    Panama City Florida
    X 2 you will never regret the extra money spent to rebuild the front suspension, when I lost the tread off of my tire at 65 MPH I was glad mine had been gone through and rebuilt, yeah I messed up some small things but I did maintain control of the car and got it stopped.
  8. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
