Front end Alignment.
Discussion in 'Technical' started by Bioinfomatic, Aug 14, 2008.
  1. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    How do I adjust the camber, caster, and toe on my 77 maverick?
    (The wheels are wearing thin on the outside.)
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Camber is adjusted with the eccentric located on the inward mount of the lower control arm.
    Caster is adjusted by lengthening and shortening the front strut rods.
    Toe is adjusted by turning the adjusting sleeve which connect the inner and outer tie rods together.
    You really need a machine to do the job properly.
  3. newtoford
    newtoford Member
    New Castle Delaware
    or a bubble level :)
    jk jk
    most shops will align your car for about $70
  4. rayzorsharp
    No way to get it right without an alignment machine. You might get it close but I'm betting it's close right now. It doesn't have to be off much on either of the specs to get premature tire wear. If you have to keep replacing tires...well, an $80 alignment will sound real cheap soon.
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
  6. newtoford
    newtoford Member
    New Castle Delaware
    well i had 2 area shops quote me between 60 and 70 and a 3rd shop did my friends cougar for $65. $39 does sound like a good deal
  7. rayzorsharp
    The prices can vary quite a bit from shop to shop. I have 3-4 cars aligned every week for my body shop. I have noticed that prices have increased the last 6 months along with everything else. So if you get one for $69.95, don't gripe too much because I just paid $79.95 for one at dealership cost by a local tire store. I usually let our service dept do them for me and I only have to pay the technician time but ocassionally have to sublet one out if they can't get to it. I gotta get the cars delivered! :huh:
  8. bmcdaniel
    I don't have a "machine" but I do have slide plates, caster/camber and toe gauges and a laser level. I get just as accurate results as an alignment rack, just takes me a little longer 'cause I'm working on the floor of my garage. Two or three alignments and the tools pay for themselves. Wonder how they did alignments before there were computers and machines? :rolleyes:
  9. bmcdaniel
    One thing to be careful of when a shop aligns our old cars, the specs they have are for running the original bias ply tires, so if you're running radials (and who isn't nowadays) the specs need to change.
  10. blugene
    I call :bs:. How are you gettin so many cars done when your on here all day?! [​IMG]
    Just make sure they don't do the alignment and charge you saying you need some parts... unless they will redo it for free when you replace them.
  11. rayzorsharp
    Didn't say I was doin them myself dummy. My phone is sitting right next to my mouse pad so I don't have far to go. Then my porter brings the car where I tell him to. :)
