Front end scream of death
Discussion in 'New Members Forum' started by customgirl1, May 13, 2007.
  1. customgirl1
    customgirl1 New Member
    Alberta, Canada
    1975 comet gt
    My 75 comet gt just passed safety. but drive out of your garage and the front end screams uncontrollable.
    front end just had ball joint, steering rack, and a wheel alignment done.
    was quiet for about a few days and then you drive and the tires scream.
    any suggestions on what perhaps was missed in the inspection.
    customgirl@hotmail.com
  2. 71gold
    :Welcome: :Handshake
    check the frontend and make sure everything is still tight. :yup:
    let us know what you find. could be something broken.
    ...:bouncy: ...
  3. don graham
    i'd have it checked out before driving it too much. could be a safety item.
  4. maverick75
    :Welcome:got pics?
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Wheel bearing ..
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Something might have slipped, have it checked immediately.
    Dan
  7. 390S302
    390S302 Member
    Johnstown Pennsylvania
    1966 cyclone & 1974 comet
    make sure lugs tight if you have custom wheels
  8. DonCARLSON
    DonCARLSON Member
    St.Augustine Fl.
    1970 maverick,1974 Maverick
    Sounds like something in the alignment was not adjusted properly,or not tightened and has become out of adjustment. you shuold not drive the car until someone checks out the front end.
  9. customgirl1
    Alberta, Canada
    1975 comet gt
    Thanks
    Thanks everybody for your suggestions, the car goes in the shop on wed for re-check on front end. does anyone think the front end scream could be from the camber being off.
    also, any ideas on what i should be looking for, for front end springs, as this car sits really high in the front.
    thx,
    custom
  10. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    :tiphat: Howdy & :Welcome: Most definately......It very well could be your front end alignment out of adjustment(y)
  11. 71gold
    a lot of us just cut 1 "coil" off of the spring itself. (y)
    you might want to do this before you take it to the front end shop.
    ...:Handshake ...
  12. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    I know this sounds stupid but, disc brakes? Did you check for rocks stuck in them or wheel bearings. Just my two. Good Luck!
  13. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    The info you gave wasn't much on details... what exactly kind of scream are you talking about?? When you say uncontrolably I here the sound of a very loud loose belt squealing reallly loud to the point that it makes you cringe???
    I know it's prolly not a belt but that was just an example. Does it sound like tires squeeling like when you lock the brakes? Does it sound like metal to metal squeeling like when your brake pads are getting low? Does it sound like the metal to metal like a bearing locked up like a worn out electric Drill??
    My fist guesses would be wheel bearings or brakes are locked up or like someone else said if it has disc brakes then maybe soemthing stuck between the pad and the rotor
  14. hotrod-daddy
    hotrod-daddy Member
    If the squealing goes away when you turn the wheels, or only comes when you steer straight.......it is more than likely the tires, Your front end is out of alignment !
  15. 71gold
    could be P/S pump :huh:
    ...:yup: ...
