front floor pans?
Discussion in 'General Maverick/Comet' started by Melvis, Sep 3, 2014.
  1. Melvis
    Melvis Member
    Milford, IL
    73 Chevy BelAir
    Will front floor pans from a 77 4 door work on a 74 2 door? Only need section under feet and up about 6 inches.
  2. Craig Selvey
    Yes they will work.
  3. Paul Masson
    1971 Grabber
    I did it the OTHER way around... 2dr floor pan into a 4dr car!! LOTS of spotwelds to drill out! It's the rear pan that makes-up the difference. This one was cut/drilled out at the factory rear seam. You can see the amount of the old rear floor that I had to 'make'.
