HI I'm Putting a 302 in a 77 mavrick and I'm not sure which one to use .. My block is not drilled or marked for a side dip stick. Drag car only.. Thanks Tim
If you are using all stock Maverick front suspension, you will need a front sump oil pan A front sump pan is what came stock on all Mavericks
This is the one that has been on Maverick for a lot of years.....although it's a 351w.....................#39025 is the Milodon part number. My Maverick is a drag only car also.
You have to use a front sump on a stock Maverick suspension. I use a Moroso 7 quart on my drag only car.
