front suspension replacement
Discussion in 'Technical' started by my70, Jul 13, 2014.
  1. my70
    my70 New Member
    okc
    70 maverick
    what year of Mustang 5 lug pattern would I be able to fit I'm do the front end of my 70 maverickI want to replace the whole suspension I have a4 lug now want to switch to 5 lug
  2. jtown77
    jtown77 Member
    Arizona
    71 Comet
    :Welcome: from Virginia Beach. Is that Oklahoma city?
    I don't know about Mustang front end. But you can order a complete bolt on 5 lug disc brake kit for around $600 form period perfect parts.
    It comes with everything, spindles, bearings, rotors, calipers, brackets, master cylinder and proportioning valve.
    good luck.
  3. Dave B
    You don't need to replace the suspension, just the spindle. Anything from a 68-73 Mustang will fit, with the matching outter tie rod. Most Fords used the same 5 bolt pattern.
  4. blugene
  5. Krazy Comet
    Mustang five lug disc brakes are basically same from '68-'73, with Cougar using same... The spindles and tie rod pins are slightly smaller on the '68-'69 so will require outer tie rods as well(that is unless you have a 69½)...
    Above also applies to '68-'71 Fairlane, Torino, Ranchero, Cyclone etc, incl the '68-'69 having smaller spindles... I have a '69 Torino setup on mine...
