Front suspension/steering rebuild
Discussion in 'Technical' started by ForrestMav, Oct 27, 2015.
  1. ForrestMav
    ForrestMav Member
    Alabama
    73 maverick grabber 302
    I have bought all moog replacement parts for my 73. I rebuilt the power piston and control valve, so basically I am swapping all parts. I have installed all the new parts but do not know where to start to making all the adjustments. Do I start with the tie rods for the LCA or the eccentric bolts or the steering linkage? Are there certain measurements to start with and then fine tune? I guess I just need a starting point because I do not want to spend hours chasing my tail. I looked for threads with a how-to but have not been successful.
  2. Krazy Comet
    Front end adjusts in this order, caster, camber, toe-in...
  3. Jamie Miles
    Do you have access to proper equipment to do an alignment? If not, I'd get the toe as close as possible with a tape measure, take it to a shop and have it done right.
    71gold likes this.
  4. 71gold
    find someone that's old school to do it and take them the specs...:yup:
  5. ForrestMav
    ForrestMav Member
    Alabama
    Ok, thanks. I was planning on taking it to someone but just wanted to get it close, to be able to drive it there. Now on to xmsn/engine rebuild. Whoo hoo, making progress
  6. Krazy Comet
    As long as wheels are setting approx same in wells(caster)[will be closer in front than rear]), are setting straight top to bottom(camber, can use a plum-bob), and toe is close, It'll probably drive OK... For toe-in measure from center of tread at exact same height front and rear... Toe is the critical adjustment, have it off even slightly and tires will quickly wear...
    I've had mine back apart swapping springs after replacing all steering/suspension components and have experimented with adding additional caster... Drives good and at approx 1000 miles is yet to be aligned...
