front suspension
Discussion in 'Drag Racing' started by hectorsalinasx, Sep 8, 2015.
  1. hectorsalinasx
    hectorsalinasx Member
    1969.5 Maverick
    Quick question, How is the front suspension in terms of drag racing....good?
    Ive been looking into the AJE k member, but i have never known how is the stock suspension in this situation.
    Thanks in advance guys.
  2. Hotrock
    Munroe Falls, Ohio
    How quick do you plan on going?
  3. hectorsalinasx
    1969.5 Maverick
    Low 10's
    The plan is 408w, aluminum heads, nitrous.
    No interior, as much fiberglass body as possible, lexan windows.
    Next year i wanna start on the front suspension that why im asking, i dont wanna start buying parts and then decide not to use it like it happened with the interior.
  4. bb466
    bb466 Member
    west virginia
    72 Mav
    I installed a complete AJE kit over the winter, built a new 427, going 9.50's @ 141. LOVE the way it drives now!
    Wish I had done it years ago. Do it! You won't be sorry.
  5. hectorsalinasx
    1969.5 Maverick
    Damn 9.50's is faast, what kind of setup do you have?
  6. ray-g151
    ray-g151 Member
    Hatboro, PA
    1971 Maverick 412w , 1969 Cougar 427w, 1973 Maverick 306w
    Agreed. Mine is done, just haven't tested yet. I've been too busy with family life and racing the Cougar. Can't buy time, the 412 engine is done and has been ready to go in for the last 3 months.
    What headers did you go with? I am running the Hooker Super Comps 2" pri. and 3.5" collector that I modified on the driver side. What struts are you running?
  7. bb466
    bb466 Member
    west virginia
    72 Mav
    Hey Ray, good to hear from you! A buddy of mine had a set of used Stahl headers for a Fox Body. 2" primaries and 3.5 collectors. Had them tweaked by a fab guy and they worked out nice. Both sides go in from the top with no problem. Same struts you have, KYB adjustable. Installed Calvert rear shocks. Big difference. No large wheelstands, just hook and go!
    Hector, set up is a Dart block based 427, AFR heads, C-4 trans, 9" rear with a 4.22 gear. 10.5 Hoosier slick. Those 9.50's were in mid to high 90's temps. Should do better when the weather decides to cool off.
    hectorsalinasx likes this.
  8. ray-g151
    ray-g151 Member
    Hatboro, PA
    My headers are the same way, just drop them in from the top. Had to change the converter and trans last week in the Cougar for the Yellow Bullet race, had to turn the trans sideways to get past the headers. What a pain, can't wait until that car gets the AJE kit. Hopefully I can have the Maverick ready for MIR in October.
  9. bb466
    bb466 Member
    west virginia
    72 Mav
    Yeah, looking forward to that. When I got my mess all together, bad oil leak at the rear of the engine. Had to pull the tranny. Came right down between the headers! Oil galley plug wasn't tight.
  10. Blazzinwarthogg
    Blazzinwarthogg Member
    1971 Ford Maverick
    bb466, Do you have pictures of your k-member set up?
  11. bb466
    bb466 Member
    west virginia
    72 Mav
    Just go to Anthony Jones Engineering/ AJEsuspension. It's all there, installation pics, etc.
  12. stockish
    stockish Member
    1973 ford maverick
    Hello bb466
    Im just trying to find the k member you used.I went to aje web site didn't find listing for our cars. I have 73 maverick 2 door just starting the build. Im still trying to figure this all out.
    Thanks in advance
    Stockish
  13. bb466
    bb466 Member
    west virginia
    72 Mav
    The kit is the Colt-65 kit for the early Mustangs. K member is a bolt in, had to relocate the top of the struts slightly. Call AJE at 1 800 877 7233 and talk to James. He will answer all your questions. I used the KYB adjustable struts and the 87-93 Fox spindle. 125 lb springs on the struts and adjustable lower control arms.
  14. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    Did the aje kit change the distance from wheel to wheel in the front or is it identical to original?
  15. bb466
    bb466 Member
    west virginia
    72 Mav
    I didn't take an exact measurement, but is a little wider.......no more than 1.50 or 1.75 inches overall. Not sure if the difference is in the suspension kit or the brakes. I have Wilwood drag brakes. All in all I think it gives the car a better look and stance. JMO.
