Front sway bar bushing
Discussion in 'Technical' started by Scotty P, Apr 23, 2006.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    How difficult is it to get these on? I am start the reassembly and the old ones look good. Just don't want to hit a major snag in the reassembly if these are tough to get over the mounting ends. Scott
  2. Scotty P
    Scotty P Member
    santa rosa, ca
    anyone? Chiltons said to cut them, really?
  3. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    If you're talking about the bushings for the mounts, mine were cut from American Pony to get them over the bar.
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    They are very easy to install. First mount the frame bushings and then the end-link bushings. I highly recommend poly-urethane sway-bar bushings from Energy Suspension with the grease zerks. They will be quiet, while non-greasable poly-urethane bushings squeak annoyingly. Stock rubber bushings , although quiet, flex too much, and rot from exposure to the elements. The urethane never rots...
    *Edited for typos
  5. Mavaholic
    The PST bushing had a split in them so they slid on pretty easy. Not sure if rubber ones do or not but I wouldnt think it would be too hard.
