Front turn signal plug...
Discussion in 'Technical' started by David74maverick, Sep 6, 2013.
  1. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    Ok I feel like a idiot even asking this but how do I disconnect the front turn signal plug from the grill? I'm trying to get the grill off and everything is good to go except the turn signals are still plugged in and I can't seem to get them off... I tried searching it but came up with everything but what I'm looking for.
  2. rthomas771
    If you’re asking about the electrical connection...They just pull apart. Don't know what you mean about “plug from the grille”, but the housing is bolted to the radiator cradle and will come off with the grille then you will see how to get things apart
  3. David74maverick
    Arizona
    I've got the grill unbolted from everything else but I can't get the electrical connection to come apart so I can actually remove the grill... I even unscrewed everything I could from the grill but nothing is giving way...
    So the 3-wire plug is supposed to just come straight out of the lens? I tried a screw driver to help pry it out but nothing gave way, I was able to twist it a little but that's it.
  4. 71gold
    got a pic?
  5. rthomas771
    The parking light bucket has a pigtail about 9"-12" long. It unplugs from there. http://www.1bad6t.com/sale/fs_3298.jpg
  6. Craig Selvey
    Just twist and pull on the connector on the end of the pig tail. Sometimes they can be stubborn.
  7. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    The bulbs are so stubborn I've taken to using a short piece of hose with an ID a bit smaller that the bulb to twist it. Better the hose than having that bulb disintegrate in your fingers!
  8. Craig Selvey
    I am talking about the plug in the very bottom of this picture.
  9. David74maverick
    Arizona
    Alright, for some reason I was expecting it to disconnect from the bucket end... like every other light on the car... thank you.
  10. Craig Selvey
    Yes they do....but you sometimes have to twist them a little to persuade them to come out. (y)
  11. David74maverick
    Arizona
    So... would they disconnect from the bucket on a '74 maverick like the comet one shown above and have the pigtail or is it just the pigtail. thanks.
  12. Craig Selvey
    1974 would have the pigtail as pictured.
  13. David74maverick
    Arizona
    ok, on a side note how would I change the bulb? from the front?
  14. 71gold
    :hmmm:...I've never had one of them to...twist out.
