front turn signal problems
Discussion in 'General Maverick/Comet' started by Eli Lacy, Aug 20, 2015.
  1. Eli Lacy
    Eli Lacy Banned
    1970 ford maverick(grabber clone)
    IM having problems with my front turn signals... The rear come one and blink, but the front only come on and and glow a steady burn.... Anybody have any suggestions???
  2. 71gold
    check all grounds, starting with inside the sockets...:yup:
  3. Krazy Comet
    Grounds are first on list... There are a pair of small hex head screws that ground the wires from sockets on either side of radiator...
    Does the front burn steady with all the other lights off, or do you mean with park/headlights on as well?
    Eli Lacy likes this.
  4. Eli Lacy
    Eli Lacy Banned
    The do come on with parking lights, but when you turn on signal only the back blink.... The front doesn't do anything. Both radiator grounds are connected but this afternoon.I will reground them. How do the sockets ground inside?
  5. Eli Lacy
    Eli Lacy Banned
    Parking lights come on just don't flash, they don't. One on aT all using turn signals
  6. Krazy Comet
    The park lights never flash, the second filament in bulb is what operates with signals... Though I kinda doubt it, could be as simple as bad bulbs(swapping with rear will test them)...
    The sockets sometimes get corroded inside so the shell of bulb isn't grounded, a ohm meter will tell you if that's the problem... To test check resistance from ground wires mentioned to bulb base(outside shell)...
    BTW do the dash indicators flash?? If not the signal switch is likely defective, or maybe a bad connection on plug from column... If they do problem is between signal switch and socket(again assuming bulbs are OK)...
  7. Eli Lacy
    Eli Lacy Banned
    My car is a.70 the.rear marker lights flash. The front markers don't, neither do.my in the.grille sport lights
  8. Eli Lacy
    Eli Lacy Banned
    Thanks Tom, found that the bulbs are lol corroded, and also the housing is very rusted... will replace them tomarow
    Krazy Comet likes this.
  9. Cometgt_71
    Cometgt_71 Member
    Saskatoon, Saskatchewan, Canada
    71 Comet, 2 72 Comet GT's , 73 Comet GT, 77 Maverick
    Mine's doing the exact same thing. Look forward to hearing what you find.
  10. Cometgt_71
    Cometgt_71 Member
    Got mine fixed. The grill was replaced at some point, and whoever pulled this one from another car, just snipped the wire off. Then, they had crimp connectors to splice the plug and ground eyelet onto the donor grill. Guess it's hard to unplug and remove a 5/16 bolt. Anyways, the connectors were corroded so I soldered them up, the right way. The front lights are exposed to way more water etc, so they go bad first. Just unplug your turn light harness and use a test light to check power on the harness with the signal light on, key forward.
  11. Eli Lacy
    Eli Lacy Banned
    Ok so the housing was bad, and needed new bulbs... while I had them apart I cleaned them.up pretty good. And they glow like new
  12. Cometgt_71
    Cometgt_71 Member
    I put some dielectric grease in the bulb socket and on the harness plugs; stop the corrosion
  13. Krazy Comet
    :thumbs2:, glad you got it fixed...
