Hey all, does anyone have a picture of the front valence brackets on the car, where they mount? Not the long flat pieces on the sides, but the other ones. I have all the parts except for those, and I was going to fabricate something. Thanks!
If that is the only other bracket, then yes! I had no idea it attached in that location... i thought it would have been more toward the middle. Thank you!
I installed the new skinny bumper/ bumper insert/ valence today... the front of the valence seems flimsy, is there supposed to be something attaching it to the car, like a bar, or are the bolts simply for a license plate bracket? Either way I will make some sort of support to strengthen it.
You needed to change the center grill support as well. The 1970-1972 style is made to support the front valence in that middle hole.
Ah, any idea where I might find something like that? Sounds hard to find, I have a feeling I may just have to fabricate it to make it work. Also where would I find a license plate bracket? I assume they are not reproduced.. The parts I put on the car is what came with it, so I'm in the dark as far as what is supposed to be there
