Front windshield gaskett
Discussion in 'Technical' started by blugene, Nov 9, 2009.
  1. blugene
    Does the thicker part go towards the car? :huh:
  2. Mavman72
    Thick bead faces interrior...
  3. blugene
    Thanks. :)
  4. Mavman72
    Any time Gene...:tiphat:
    Just be certain it fits the windshield properly before you try to install it.
  5. blugene
    I'm putting it on the glass to just lay it in place so I can get it off of the floor.
  6. blugene
    Do I need to lube the gaskett or anything? Will I be stretching it over the edges? When actualy installing the glass will the gaskett go in the opening first or on the glass?
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    i need to do my front windshield
    where can i get the seal cheap ??
    post pic's if you can on how you did this install
  8. blugene
    Heck, the crickets are loud in here lol. I'm still waiting on an answer. I need to know quick cause I am sitting here needing to move the glass.
  9. rthomas771
    I would wait until I got ready to install the windshield just in case I needed to remove the rubber to put sealer between the rubber and glass. Also the seal will be putting unneeded pressure around the edge of the glass and it might crack. In other words put the rubber seal back in the bag and step away slowly.
  10. vinceking001
    vinceking001 Gearmonkey
    Nashville, TN
    1975 Ford Maverick
    The seal is put around the windshield first. As added measure, you can apply a touch of windshield sealant to the inside channel of the seal (the part that hugs the windshield) to guard against leaks. You then put windshield sealant around the windshield opening of the car. You then take a piece of string and wrap it around the seal with a good overlap at the bottom. Then with you and a buddy, drop the assembly into the frame trying not to get a bunch of sealant on the thick inside part of the gasket. Once the thick part of the gasket has been dropped inside the windshield frame, locate your string ends at the bottom of the windshield and slowly pull them toward you to pop the inner part of the gasket through the windshield frame.
    If you are having a hard time making a visual picture from my words, this article is among many helpful web articles for windshield installation. I've seen 2 or 3 out there (one of them even referenced in this forum under windshield installation) for vintage mustangs which is the same general thing.
    http://www.secondchancegarage.com/public/mustang-headliner2.cfm
    Good luck, brother. Most importantly, TAKE YOUR TIME and have a buddy to drop the shield in.
  11. vinceking001
    Nashville, TN
    1975 Ford Maverick
    There is a no cheap gasket for this vehicle. The only gasket I've seen for this vehicle is going on ebay for $60 plus shipping. And they have the gall to charge $15 to ship it. I checked my local windshield place and they told me they couldn't even get the gasket anymore. So....Since it appears only one company makes then, plan to spend $70-75 for the gasket. If you get a quote from a glass company make sure it includes the gasket. They usually don't replace gaskets on most cars when they replace the windshield so it isn't likely included in the quote.
    Good luck
  12. blugene
    DUDE! Don't say crack! :(. I am not wanting to install at this time. I just need it in place to have it somewhere other than the spare bed room. Anywhere else would be dangerous.
    I was under the impression that it just sits around the glass without pulling on it. :huh:
  13. Jeff S
    Jeff S Member
    NoVA
    none
    You can mail it to me and I'll hold it [​IMG]
    I think the rubber is more likely to stretch over time then cracking the glass...considering your gasket has been on your car for 30+ years and havent cracked it yet from the pressure.
  14. blugene
    My new glass AND gaskett is the discussion.
  15. rthomas771
    It doesn't "just sit"...It should be a very tight fit. You need to pull hard to get it around the glass. Without the cars channel to keep it it from bowing it could squeeze too tight on the glass and any undue stress or shock could have unwanted results.
