fuel filter
Discussion in 'Technical' started by aubman82, Jul 25, 2006.
  1. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    I'd like to be sure I'm getting clean gas through the system. Would there be any problem installing a clear fuel filter before the fuel pump to check for debris?
  2. Jamie Miles
    I have mine installed after the fuel pump. I have to change it about every 5,000 miles because they get to where they don't want to let gas through for some reason, meaning when you floor it or climb a big hill, it will start to loose power and cut out. Mine never has much of anything in it, but I figgure it never hurts to have an extra filter there.
  3. Robby5323
    Robby5323 Member
    East Texas
    I don't think you would have a problem with it. Just keep an eye on it and be sure it doesn't become clogged. You should be fine.
  4. afjaybird
    afjaybird Member
    vandenberg afb
    70 maverick grabber
    has anyone ever used clear lines? i was wondering if gas would eat through them or not?
  5. Jamie Miles
    Yes. I used clear line on my '74 Grabber because my uncle had it laying around and gave it to me. It was the kind that resistant to chemicals, acids and solvents. You can see it here in my gallery: spark.jpg
    It didn't melt or anything, but after several months it started to yellow (as you can see) and it got kind of hard. When I swapped the engine over to my '72, I just used standard black hose.
  6. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
  7. Rando76
    Rando76 Member
    Claremore, OK
    I agree, the glass filters are horrible. I tried using them and it seems like the fittings break too easily. :slap:
  8. Jamie Miles
    Yep, the FRAM is what I use also. Get it at Wal-Mart for like $4.
  9. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    i was having problems with a flooding carb. the solution was two filters. one near the fuel tank made of metal 3/8" and a glass fuel filter after the mechanical fuel pump/ holley fuel pressure regulator one year ago and no more floodding. you have to keep a eye on the glass filter !! they come lose sometimes !!
  10. 71gold
    i mounted one of the ...big rig...filters on my mav. it is plumbed between the fuel pump and the carb. it is about the size of a large screw on oil filter and filters water also. i can't find the pic. of it :hmmm: ..frank...:bouncy:
  11. blugene
    And you made fun of my air filter that filters oil :p .:rolleyes:
    My opinion is that although you can install a gas filter before the pump, you should consider the pump is not really designed to suck too hard. If the filter before the pump begins to get dirty, you will notice driveability problems sooner than one getting dirty after the pump. If I were to install one before the pump, it would be a large clear one. You should have a sock on the end of your pick up tube, that should be all you need before the pump. :2cents:
    This leads me to wonder, how about a magnet placed just inside the sender opening? Placed as low as possible though. Any body done that?
  12. dmhines
    Cumming, GA
    One benefit of having the filter before the pump is that there is no pressure ... just vacuum so there is not chance of it leaking.
  13. Jamie Miles
    Dan makes a good point. I have had problems with mine leaking in the past when I didn't have the clamp tightened down enough, and that's just not good. :tsk: When I put my '69.5 together, I think I am going to put the filter before the pump. I'm going to re-route my steel line so that it comes out behind the shock tower instead of in front of it. Then I can hide the filter behind the shock tower.
  14. bmcdaniel
    It's recommended that you use a stainless steel or nylon mesh type filter before a fuel pump, whether it's mechanical or electric. Mesh filters have a lot less resistance to flow compared to paper filters so the pump doesn't need to suck as hard. Many electric pumps can't suck at all, that's why you have to mount them lower than the fuel supply to keep them primed.
  15. 71gold
    keep the hood closed then you can hide the shock tower the filter is hiding behind :rofl2: :rofl2: :huh: ...all but Jamies friend frank... :bouncy: J/K
