Fuel gauge and sending unit
Discussion in 'General Maverick/Comet' started by NWMO_Maverick, Jul 2, 2018.
  1. NWMO_Maverick
    NWMO_Maverick Member
    Northwest MO
    1976 Maverick 302, C4
    Alrighty,
    I have the voltage trasformer and gauge back together and wired in. No response with sending unit, but if I pull the connector plug and provide a connection between the two female connections on the plug (presumably grounding the connection), it will chase right to full. I assume I need to pull the sending unit and clean/investigate.
    What is the range of ohm sweep I should find? And I assume I need some type of gasket for putting the sending unit back in?
    TIA,
    C & G
  2. 71gold
  3. NWMO_Maverick
    Northwest MO
    Thanks Frank.
  4. stumanchu
    stumanchu Stuart
    Portland, OR
    Frank is right. I checked mine when my tank was out. It went from 20 to 80, but the gauge works fine.
  5. NWMO_Maverick
    Northwest MO
    Thanks stumanchu.
