Fuel Gauge
Discussion in 'Technical' started by chalito, Feb 5, 2008.
  1. chalito
    chalito Member
    Hi:
    I just fixed my fuel gauge :yahoo:...In order to calibrate the needle, do you know what's the range of voltage that the regulator send to the gauge?...I asume 0 when the tank is empty, but when it's' full ??
    Are there problems if you bypass the voltage regulator?
    Thanks,
    Chalito.
  2. Mavman72
    I dont know the specs but you can map it yourself with a volt meter.The sending unit is just a rheostat(like a dimmer switch for your lights)and the guage is basically the light bulb.Good luck.
  3. rthomas771
  4. chalito
    chalito Member
    thanks for your answers.
    The voltage regulator then limits the fule gauge voltage to 5 volts, I can now calibrate the needle.
  5. rebeltez
    rebeltez New Member
    louisiana
    1973 maverick
    where is the fuse box panal on a 1973 302 maverick?
  6. rebeltez
    rebeltez New Member
    louisiana
    1973 maverick
    where is the fuse box for a 1973 maverick?
  7. newtoford
    newtoford Member
    New Castle Delaware
    under the dash on the far left. kinda near where your left knee would be when your sitting in the driver's seat
