Fuel Injection (or Forced Induction) fuel supply for Maverick
Discussion in 'Technical' started by Powerband, Mar 2, 2016.
  1. Powerband
    Powerband Member
    NY's \H/
    Fuel Injection (or Forced Induction) fuel supply for Maverick discussion:
    Current Carbd' forced induction project needs some help. Typically FI requires a RETURN type fuel line supply using a high pressure fuel injection type pump and a BYPASS type fuel regulator to reduce to required pressure.
    I am considering modifying the fuel tank on my 1974 Mav to accept a return line or if needed - using a fuel cell.
    The 74 has a return VENT line but probably is too small to use directly. I believe the return also has a one-way or some valving .
    Pic' of tank return would be helpful
    Simple solutions or suggestions appreciated , personal anecdotes not so much ...
    have fun
  2. 71gold
    what pressure do you need to maintain?
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Look at my showcase post.
    Micah
  4. Powerband
    Powerband Member
    NY's \H/
    .... whats a showcase post?
    here's a related post i made on Turbo forum:
    Planning on @ 10 pounds boost for my purposes. If my blow-through carb only needs @ 3-4 PSI at NA can I use a typical NA type NON-RETURN regulator and an NA-non return type fuel pump that can put out up to @ 15psi?, seems easy enuff...
    thanks
  5. 71Mavrk
    71Mavrk Member
    Nevada
  6. bmcdaniel
    Are you looking to stay carbed?
